theRoadrunner's avatar
Nov 20, 2017
Terry Quantum AX6 voltage converter! Where could it be?
I have a problem with my 2004 Terry's converter. Battery not staying charged. Had to boost it with a battery charger.
I guess I will have to have the converter replaced but I am hoping the RV guy knows where the thing is...
Anyone know exactly? It may be behind the fuse panel but that is a wild guess.
The RV is on a permanent site in Florida and I am in Ohio...
Thanks in advance if you have an answer! :)
❚ Did you miss the FTS "Announcement : READ BEFORE POSTING HERE"?
    Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum sites,
    member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related
    questions. Instead, select the Sub-Forum which corresponds to the subject of your topic.
    Thank-you!
    Moved from FORUM TECHNICAL SUPPORT
  • newman fulltimer wrote:
    on your doorside large storage behind the false wall right by the doorside wall
    i believe its six or eight screws take the panal out
    your doorside large storage behind the false wall right by the doorside wall - I do not understand what you are talking about... sorry!
  • on your doorside large storage behind the false wall right by the doorside wall
