pnichols
Oct 07, 2017Explorer II
MEXICOWANDERER wrote:
My car uses expired dinosaurs.
Range is around 500 Km
Around 15 minutes to "recharge"
Can see 99.9% discharges for say 200,000 miles
Motive re-power for around a thousand dollars
Pollutes less than one of " 's" mansions
But I really could use a golf car to get around Las Penas.
I will switch to an electric car
The day after
I buy a gasoline toaster
David ... nice list above, but you forgot one item: If you never want your car to run low on it's expired dinosaur supply out somewhere on a lonely road, you can replenish it's supply in minutes from a simple container carried in the trunk ... instead of sitting in the hot sun (if it's shining) for hours while the solar panels you rolled out on the ground slooowwwly fill up a battery so you can be on your way - if you're still alive. :( and :B
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
