wa8yxm
Apr 03, 2014Explorer III
donandmax wrote:
I'll second that, happened to me many times back in the 60's when I was a radio TV repairman.. Of course I learned from each experience. Yeah they do bite.
I can give you a bigger bite.. once picked up a trasmittter chassis, per the diagrams the highest voltage on it was 12vac Filiment voltage, With dry hands not even a tickle at 12 vac.
Found out the prior owner had powered the receiver off a dropping resistor, Instead of a dual voltage power supply, he provided 500 VDC to the transmitter full time, and ran it through a resistor to get the lower voltage needed in the receiver... That one put the lights out (Really, When I made contact (And tossed it) either I, or the toss pulled enough current to blow the fuse and put the lights out)
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
