D_E_Bishop's avatar
D_E_Bishop
Testing a Battery Isolator Controller
I had a problem last week in "Q" where during the drive from Los Angeles to "Q", my coach batteries did not charge from the alternator. I pulled out the trusty cheepy, cra!!y HFT DMM and hooked it up to the house side of the Isolator Relay. What I saw was after the engine warmed up and the chassis battery was charged, the relay would energize for a few seconds and then drop out, then energize a few seconds later and then drop out.
It pretty much conformed to the specs of an Intellitec BIC, except it would not stay energized.
For what ever reason, I pushed the AUX Batt switch a few times and finally the solenoid stayed energized.
I THINK, no nameplate available, that I have an Intellitec BIC #11-00200-00, which has been replaced by part # 00-00131-00. I will go through the logical step by step process of checking the seven wires in the bundle for proper operation both in static and active modes.
The wire bundle from the Molex connector is color coded but there isn't any schedule I can find. I assume the connector was wired by a third party to Fleetwood's specs and nothing in any of their schematics shows the BIC and solenoid.
Have any of you had problems with the BIC or do any of you have the wiring schedule?
  • If it drops out, I would clean the contacts on the coil., both inside and outside of the case.
    Check the connections on the control wires.
    This the controller that should operate the relay. Intellitec 00-00131-00
  • I've taken several apart and cleaned the copper disc. It can involve drilling out rivets. Possibly the solenoid engages but no house battery voltage change is detected so it disengages.
    I've also used the aux start to get a failing solenoid to engage.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
