Old-Biscuit
Jan 13, 2014Explorer III
Matt_Colie wrote:
You have nothing you can't run alone on the 15amp feed.
You have almost nothing that you can run with anything else on the 15 amp feed.
So, shut everything down - And I Mean Everything.
This includes the converter. Run on the housebank for the tests.
Power up one, test it and shut it down.
When everything have been tested and confirmed, now power up the converter and relax.
Matt
X2
And occasionally touch that adapter and check if it is getting hot.
Warm is OK but if hot throw it away.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
