wa8yxm
Jan 14, 2014Explorer III
I would upgrade that extension cord to a 12ga.. Most "Contractor" cords are 14 or 16. When I had a house the RV had a 20 amp feed. I could run ONE of the following with no problems
Space heater
Air conditioner
Microwave
Water heater
Firing up 2 might be possible but good chance of the click of darkness (Tripped breaker)
Most of those devices will also work on 15 amps.. Try it, with a 12ga cord though, and see if it trips the breaker. If not, you great, if it does and breaker is 15 amp, or other things on that circuit.. Well you figured it out.
Recommendation: IF you decide to have an electrician put in a proper RV circuit, make it 50 amps.. Less chance he will screw that up.
Space heater
Air conditioner
Microwave
Water heater
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
