Snowman9000's avatar
Snowman9000
Testing electric brakes, Update.
I want to test out the electrical side of our fivers brakes. I read an article giving the max amp draw for four 10 or 12 inch brakes as 11.3 - 13.3. I can use a 20 amp multi tester. My thinking is to disconnect the house from the house batteries, make sure the breakaway switch still has power, then pull the pin and check amp draw at the battery cable. Is there a hole in that idea?
This would be just the first step, letting me avoid taking apart the wires at the hubs. But if the amps are low, I’ll have to get down there and proceed further.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
