Ramblin__Ralph's avatar
Jun 07, 2017
Testing for propane leak?
While sleeping in my truck camper last night, I smelled what I'm pretty sure was propane odor. No propane alarm sounded and my detector is only a couple of years old. So I got up at 3 a.m. (yawn) and turned off the tank.
This morning no propane smell in same spot. Turned tank back on. No smell 5 hours later.
Is there some way I could do a pressure check on the propane lines, or is that an RV service tech type of job?
The smell was very localized. When I moved to the other side of my bed, it didn't occur there. When I smelled it, I was on the passenger side with my head near where the propane tank and fridge compartments are.
Thanks,
  • If the propane pressure gets low you sometimes get a smell. If it is a large leak it should shut the gas off automatically. However checking for leaks is a good idea, at least once in awhile, I test for leaks about once a year just to make sure.
  • Windex works GREAT for detecting PP leaks. It bubbles like crazy.
  • If you get a spray bottle and put some soapy water in it then give a little squirt on the connections of the the propane line. If you get bubbles forming you found your leak.
Having RV issues? Connect with others who have been in your shoes.24,267 PostsLatest Activity: Jun 14, 2025
