bpounds's avatar
bpounds
Nomad
Aug 21, 2018
Testing potential solar harvest?
Now that I have a solar installation up and running, and it's working great BTW, I feel a little under informed at times. For example, at any given point in time, what is my array capable of harvesting with current sunload? All I can see is what my batteries will accept at their SOC at that moment.
Is there an easy way to put a load on the controller? To somehow make it "gimme all you've got Scotty". With batteries disconnected obviously. Or do we just assume our array can do XYZ based on panel specs?
I feel like I won't ever see what the system can actually do, without discharging the batteries way down and then hitting the solar switch, and even then it is only a short term metric.
  • I like those graphs to see production through out a days use I wish my system had that option.
  • I'm impressed with the time you guys put into your spreadsheets. I assume you pull that out of your Morningstar charge controllers.
    So far I am really happy with the Epever Tracer MPPT. I don't think it does realtime logging. I know it accumulates a value for watts collected. I'm not sure over what time period, and if it ever resets or rolls over. It's not a value that interests me.
    It came with an MT-50 remote monitor which I mounted inside the coach, using RS485. The main monitor screen tells me the important stuff, and also is a better method of adjusting settings in the controller, than the controller front panel. I also kept my old volt meter as a second opinion, and it has the added value of reading in hundreds of a volt. Sounds silly, but I find that extra digit useful.
    It has optional modules to do Bluetooth and WAN connections. Based on reviews I've read, I'm not sure they have the bugs worked out of those. And it was super easy to pull an RS485 cable over to the trailer control panel wall.
    At about $190, it does everything I value. I think it is a good buy, as long as it doesn't blow up.
  • I'm using all Magnum equipment, readings come from the the me-arc50 mounted inside the trailer. The Lifepo4 battery readings have their own display for monitoring.
    Yes, the Morningstar MSView software logs and creates a CSV file and the rest is done in Excel.
  • epever PC software makes cute plots, never figured out to save the data.
    hers's bulk/abs early morning charging tiny 7ah AGM via epever's PC software.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
