NinerBikes's avatar
NinerBikes
The 12V power source solar panel
So I came across this on EBay... and they are very local to me... but it sounds like a $100 experiment gone bad.
The specs on this thing are waaaaaaay different than any other 12V solar panel that I've ever seen.
Max V 15.03V?
Amps at short circuit 7.92?
Vmp... 11.97
Could someone with more brain power than me check the specs on this and tell me it would charge a Trojan T-1275 without even the need for a charge controller?
What about diodes and sucking juice out of the battery and back into the panel?
Thoughts?
Funky Spec'd 100 watt panel with huge amps.
Do you run this with one of Mex's Voltage buck / boosters, then through a charge controller, so that there is enough V to charge a battery properly at bulk mode, 14.8V and give up a few amps in the process?
Need help, guys, but in layman's terms, EE's and above need to dumb it down to terms a Finance major can handle.
  • KD4UPL wrote:
    Not enough voltage to charge a battery by itself. Put 2 in series and use an MPPT charge controller and it will work fine. You could put more than 2 in series depending on what the voltage limit of the charge controller is.
    Two with my $13 gizmo limit at 32v almost as good as MPPT? Easier as a portable with two small panels instead of one big heavy one.
  • Not enough voltage to charge a battery by itself. Put 2 in series and use an MPPT charge controller and it will work fine. You could put more than 2 in series depending on what the voltage limit of the charge controller is.
  • JiminDenver wrote:
    Get them cheap enough and you could run them in series.
    That's a good idea.
  • 2oldman wrote:
    "Maximum Power Voltage ( Vmp)11.97V"
    I don't understand this either. I suspect it's in error.
    It is not in error, there are only 24 panels on it, at .5V each. Most 12V Battery charging panels have 36 panels on them at .5V each, for 18 Volts output, under maximum load. They then burn some of it off with a charge controller to get it to 14.8 or 14.4V to charge a battery with.
    This is more a Power Supply panel for day time use, not a battery charging solar panel.
  • "Maximum Power Voltage ( Vmp)11.97V"
  • I await mexicowanderer's input on this also.
    So if you need 14.5ish-15.0V to gas, you need 29 or 30 solar cells at .5V each to get that? At that point, does a charge controller become optional?
    The amps rating on this solar panel with PWM looks pretty darn good, if you could get the voltage to a usable level to recharge.
    Surplus voltage or head room, unless under direct sun, no clouds, looks a bit thin.
  • 15v panels were the big thing for maintaining remote gel emg batteries many years ago
    This would be a good maintainer using series diode protection
    It would offer low level slow recharge,
    Full top off, would take a very long time, but this could work well as storage..Or weekend extender
    A boost gizmo would be a big help .. For weekend camping use
    But not for storage use
  • Those 24 cell, 15v panels were not much use for battery charging because the battery needs 14.5ish to gas and these panels couldn't do it. ( Not enough spread between 15 and 14.5) So they went to 36 cell, 21v panels instead.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
