BFL13
May 02, 2013Explorer II
smkettner wrote:
$$ per watt is economic efficiency. Unless mounting space is limited then watts per sq. ft. is space efficient.
That is the only efficiency I know.
We have those DM panels with 22v Voc and low Isc compared with same wattage 21v Voc and higher Isc of "normal" panels.
You can have equal size equal cost for the watts panels, but one makes more amps. So why do we care about those watt thingies? You have to look at what amps you get for the size and cost.
It is amps what am!
Unfortunately, the 24v and up panels have only half the amps of a 12v panel, so now it is all up to the MPPT to make things even. Which is why you have to look at the MPPT controller too. You can't just compare panels, you have to compare the 24v panel/MPPT combo for amp making comparisons.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
