12thgenusa
May 02, 2013Explorer
BFL,
With 24-volt panels it's all about the watts. The Rogue controller is about 95% to 97% efficient and I expect other quality MPPT controllers are about the same. This means that if the array is producing 400 watts, the controller will output 380 to 390 watts. Assuming the SOC is such that the batteries an accept all of it, the instantaneous amperage is proportional to the instantaneous voltage with respect to the output wattage. This means that if the controller is charging the batteries at 13.6 volts, the amperage is somewhere between 27.9 and 28.7. No magic.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
