mena661
May 03, 2013Explorer
BFL13 wrote:Watts doesn't change on MPPT, just voltage and amps. The watts will be a little lower on the battery side of the MPPT because of inefficiencies. MPPT is a DC-DC converter that tracks panel output (watts output) in order to keep that output in the highest watt "range". Re-read Golden_HVAC's and 12thgenusa's posts. Watts into a MPPT = watts out to batteries. What I'm getting from these guys is look at the MPPT controllers efficiency rating to determine which unit is "best".
Which will do more amps to the battery at 13v and why?
EDIT: To answer your question directly, both will produce the same output because they're the same watt rating. At least on MPPT. Someone can correct me if I'm wrong.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
