HiTech
May 03, 2013Explorer
BFL13 wrote:
Right, so you are saying it "transforms" the watts into amps to the same amps level with the watts at low V and high A as it does at high V and low A ? That is my question (I think! :) )
Yes, within reason it transforms watts into any combination of volts and amps that v*a = the same watts (minus various efficiency losses).
10w that is from 10v at 1 amp can come out as 5v at 2 amps, or 2.5v at 4 amps, or 1v at 10 amps. It is a Variable DC-DC power supply that runs the solar panels at best input voltage and current combo to produce the most watts.
Jim
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
