BFL13
May 03, 2013Explorer II
Salvo wrote:
No red herring. Panel size is directly affected by efficiency. The greater the efficiency, the smaller the panel square area.
SalBFL13 wrote:
So, as long as the "24v" panels make 220w they all do the same amps for charging batteries with MPPT. So panel "efficiency" as described in the OP of this thread is a complete red herring.
Yes I see that now. Panel area can be smaller for the same watts, which is what the OP meant and he also said this has nothing to do with relative charging amps, which seemed odd at the time.
So that means the poor old OP is off the hook. (for now! :) )
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
