liborko
May 04, 2013Explorer
BFL13:
Perhaps this will help: Lets say you are charging batteries at 10A and at 14V with a charger pluged into 120V outlet. How much current will flow from the outlet at 120V?
10Ax14V=140W...140W:120V=1.17A.....so 1.7A at the input creates 10A at the output.
Now lets say you plug your battery charger into a 36V outlet. How much current will flow from the 36V outlet to produce same 10A at the output?
10Ax14V=140W...140W:36V=3.89A.....so 3.89A at the input creates 10A at the output.
If 36V and 3.89A were Vmp and Imp of the solar panel, with MPPT controller you would create charging current of 10A at 14V. With PWM controller you would get only 3.89A of charging current.
(Assuming 100% efficiency of conversion for clarity).
Panel efficiency:
Lets say you solar panel is exactly 1 square meter big. If this panel is illuminated with sun light of 1000W per square meter intensity, your panel will convert it into 1000W of electrical power, right? Wrong. All you will get is maybe 120W to 160W:
Efficiency = 120W:1000W x 100= 12%
160W:1000W x 100= 16%
Panel efficiency:
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
