wa8yxm
Dec 05, 2015Explorer III
Well I never subscribed to the "You should have two" theory, in fact I can't recall ever hearing it before.
My advice has been to ask if you want to microwave your popcorn (Lunch actuallY) and advise a BIG inverter if you do and a small one if all you want is TV. But not two. I mean why double the overhead and standby current?
Another myth I came across. now this one I USED TO believe in but then I did research.
MSW inverters are more efficient than PSW inverters.
I compared two Xantrex models, both 1500 watt so as to get as close to apples and apples as I could.
Peak efficiency on one was 89-90% on the other 90%.. (MSW) not enough difference to count.
So the only difference is Price and "May not work properly" List. Back when I did the research Xantrex had a "May Not Work Properly" list (Alas it's gone now) It was a long list and growing (May be why they took it down.. I'd hate to see a RV catch fire because of something not on that list which catches fire when plugged into MSW, like an LED night light. actually happened to a forum member but he extinguished in time)
The list for True sign inverters is a tad shorter:
Any device or combination of devices needing more power than the inverter can produce
That's the entire list.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
