BFL13
Dec 09, 2015Explorer II
ewarnerusa wrote:
Both my inverters are bargain models. The big one faults out around 14.7 V even though the rating is up to 15V. The small one does fine at the high voltages. I'm just getting the performance I paid for with the big one and exceeding expectations with the small one.
If the big inverter is wired up close to the batts it will have less voltage drop than the small inverter in the Winegard socket.
If both have the same 15v inverter shut down setting, then when the batts are at 14.8, the small inverter might be "seeing" 15v and shut down while the big inverter might be seeing 14.9 and still be running.
In the case where the big inverter is shutting down at 14.7 when it should be 15, there might be "other reasons"
A. bad wiring connection so high voltage drop
B. badly built so the 15 really is set at 14.7
C. some mix-up in how the "14.7" value was measured--where and with what.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
