MrWizard
Nov 21, 2014Moderator
No it's not
But you can try using an inverter in the vw tow powering a battery charger attached to the tt battery
Other members have done this
You might have a fussy battery
But unless you have strung new wire 8ga or 6ga in the tow..for the tt chg circuit
It's the small wire in the tow chg circuit that is causing a voltage drop and amps block so the tt battery is only receiving about 13v at low amps
Which is you're real problem
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
