dougrainer
Nov 21, 2014Nomad
If you would run a 8 gauge charge wire from your Alternator charge lug to the 7 way on your tow plug(you will have to adapt from 8 to 10 or 12 gauge at the plug to get it inside the plug. Then run a 8 gauge from your Tow trailer side to the RV battery. I will bet your charge problem will go away. Wire SIZE is critical when charging 12 volt systems. The factory tow vehicle wiring is never large enough to adequately do a good job. Also, doublecheck the ground wire also. The larger (8 gauge) ground wire is also needed. It takes BOTH large cables on a 12 volt system to flow the current needed. Hopefully you are not using the ball as the ground. Doug
14.4 is more than enough to charge your battery.
