cavie
May 06, 2019Explorer
groundhogy wrote:
Ok.. more info needed.
Contacts were almost new.
The RV is a 30A rig.
Current draw was minimal except on several cold spells when temperatures dropped below 10 I sometimes assisted the propane furnace with the built in electric back up. And this only over nights.
Assuming you are talking about the male end of the cord, the contacts in the female side were loose. That is what causes the over heating. tight contacts do not over heat.
If it's the trailer side your talking about and it has a twist lock receptical then you didn't have the twist lock tight with the locking ring in place.
