westend
May 07, 2019Explorer
bob213 wrote:
In wet conditions dielectric grease helps but it is really a non conductor. If you keep your plug blades shiney clean with emery cloth and use DeOxit you will have a better connection. Deoxit is conductive, and a cleaner.
deoxit
This "service temporairly unavailable" problem is sure getting old. Can't even make a link.
Best advice but the dielectric grease will work, too.
Mr OP, your blades on that plug may be made from two different metals. I have seen brass blades corrode faster than their plated steel counterparts. A small amount of moisture or inadvertently dropping a cord end onto the ground is enough to start oxidation. We don't need to get into electrolysis for further causes. Extension cords go bad all the time. Replace with a stout repair plug and see if your luck gets better.
