- pianotunaNomad III
valhalla360 wrote:
Unless you are leaving it outside in the rain with the cap off...once it draws the moisture from the air in the tank, it's largely done.
There is a vent in the tank, at least in mine. - valhalla360Navigator
Lantley wrote:
The real mystery is why Honda did not consider a LP fuel option?
Because fuel injection largely eliminates fuel related problems. - LantleyNomad
Grit dog wrote:
Bobbo wrote:
Because unless you go to the trouble to find, and expense to buy, ethanol free gasoline, the gas has other failings. The ethanol in gasoline is very hygroscopic. It actually attracts moisture out of the atmosphere. Over time, a problematic amount of water can accumulate. The additives also help with moisture in the gas.
This would be a case for using Seafoam in ethanol free gas as it doesn't have alcohol in it and is not hygroscopic. E10 will absorb more water and cause you less problems due to water in fuel than non-ethanol, with no alcohol additives.
Preserving fuel quality = slowing down oxidation. Fuel stabilizer is like your fuel eating blueberries, lol. It's an antioxidant.
It also puts water into solution with the fuel so it can be burned (like Heet, or.....ethanol containing gasoline).
What any of this has to do with Honda's new generator is a rv.net mystery....
The real mystery is why Honda did not consider a LP fuel option? - valhalla360Navigator
pianotuna wrote:
Jacksons wrote:
"The ethanol in gasoline is very hygroscopic. It actually attracts moisture out of the atmosphere. Over time, a problematic amount of water can accumulate."
that is simply not true. ethanol will not attract water out of the atmosphere
Sorry but it does. Hydrogen bonding causes pure ethanol to be hygroscopic to the extent that it readily absorbs water from the air.
I ran the math one time for the 220gal tank on our boat and assume the air changes over 100% once per day due to temperature fluctuation (it won't), over 6 months it was 2-3cc. On a tiny 1gal generator tank, it will be a tiny fraction of that.
If you got water in the tank, it probably came with the fuel. - BobboExplorer III
StirCrazy wrote:
note the spelling: hygroscopic...". It is HYGRO, with the letter "G." and that the general dictionary definition for a hygroscopic substance is that it can attract moisture from its enviroment. so it doesnt adsorb it but it atracts it. for example if you put a open bottle of whisky on the counter, the level wont go up.
Note that not a single person in this thread has misspelled "hygroscopic." I will not quibble about "attracting" vs "adsorbing" moisture. Moisture appears there as if by magic.
(Please note that "adsorb" and "absorb" are not the same thing, and one is not a misspelling of the other.)Grit dog wrote:
My understanding is that the new Honda generator runs on gasoline. If I am mistaken, please educate me. - snowedinExplorerThe new Honda 3200 generator looks to be the right size as it should run a 15000btu size air conditioner and the fuel injection feature should be just great. Have had two Honda Rancher ATV's with the fuel injection and never had a problem with either, they start great too.
Something to check out as an alternative now is the MXR3200 inverter generator that appears very similar to the Honda 3200 except I don't think it has fuel injection. It does have the 30 amp receptacle for the camper power cord. Search YouTube for reviews or just search MXT3200. The price is right at around $700 or less but search to see what pops up, Amazon, Walmart or whatever for the current price. Just noticed from pictures that the Honda 3200i does not appear to have the 30 amp outlet to allow plugging in the 30 amp camper electrical cord, sure hope I am wrong. - StirCrazyModerator
Well if it's not attracting water out of the atmosphere, enlighten us where it's coming from. I'm sure it's not coming from the garden hose.
short trips. when you start a car/truck/motorcycle the change in temprature in the fuel tank and the change in volume in the tank its self cause mosit air to be pulled in. then it cools down and the moisture falls out of its vapour state and eventualy settles to the bottom of the tank. thats why people who do a lot of grocery trips seam to need to use methanol (gas line antifreeze) in the winter. this allows water to mix with the fuel but it doesnt adsorb it either and isn't good to use in moderen vehicles. a water filter is the best way to do it.
The origin of the claim is that ethanol is classified as a "hygroscopic" substance, note the spelling: hygroscopic...". It is HYGRO, with the letter "G." and that the general dictionary definition for a hygroscopic substance is that it can attract moisture from its enviroment. so it doesnt adsorb it but it atracts it. for example if you put a open bottle of whisky on the counter, the level wont go up. - dieseltruckdrivExplorer II
The reason you don't often have problems is because of your gas cap. - Grit_dogNavigator III
What any of this has to do with Honda's new generator is a rv.net mystery.... - pianotunaNomad III
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 21, 2026
