udidwht wrote:
Anyone know of a generator that can be swapped in place of an in place Onan 4k relatively easily using preexisting wiring?
Another Onan Cummins unit can be installed.
That's what happened in my case - I took out the original loud Cummins Onan 2500 and replace it with the Cummins Onan 2500i inverter model, which is a lot quietertheoldwizard1 wrote:
With fuel injection it SHOULD meet CAFE and run well at altitude !
CAFE is not California Air Quality. Last I knew, California has what's called CARB (California Air Quality Board)
CAFE home page
CAFE is an eatery, or Corporate Average Fuel Economy, a standard auto manufacturers need to meet based on a set of rules from the EPA.
CAFE Home page- valhalla360Navigator
lane hog wrote:
Dumb question, but is this 3200W at 220V?
Wouldn't the 110V output be closer to 13A?
Divide wattage by voltage and you get amps.
If they put out a 110v version for N. America, it would presumably put out roughly double the amps. - TrackrigExplorer IIhttps://soundproofguide.com/eu32i-new-honda-generator-all-the-facts-eu3200i/
- lane_hogExplorer IIDumb question, but is this 3200W at 220V?
Wouldn't the 110V output be closer to 13A? - udidwhtExplorerAnyone know of a generator that can be swapped in place of an in place Onan 4k relatively easily using preexisting wiring?
Had been giving this some thought in the event the Micro4K crapped out. - valhalla360Navigator
Ranger Doug wrote:
Every Honda dealer and factory person I’ve spoken to about this generator have said the same thing. They haven’t heard anything about it. Also a lot of items available in Europe aren’t available here. Only time will tell.
Might be EU regulations forcing the shift but once production is ramped up, if it's any good, I would be shocked if it doesn't get expanded to N. America. - Ranger_DougExplorerEvery Honda dealer and factory person I’ve spoken to about this generator have said the same thing. They haven’t heard anything about it. Also a lot of items available in Europe aren’t available here. Only time will tell.
- MEXICOWANDERERExplorerI am gathering the new variant is not computer controlled fuel and ignition?
- ScottGNomadI'm thinking the EFI will be of benefit at high altitude to keep mixture in check.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
