naturist's avatar
naturist
Nomad II
Jun 08, 2016
The curious case of the funky 12 volt system
Just started having this issue with my 2007 Coachman with an Atwood converter. Had the RV plugged in all winter with the battery disconnected but on a Battery Minder, as I've always done before. The RV is left plugged in so that I can use the 120 volt circuits inside to keep a dehumidifier running and prevent that musty smell. The battery is left disconnected because the charger isn't 3 stage and ruins the battery if left charging all winter, whether you keep up with the water level or not.
So anyway, I arrived at my campsite, and unhitch, go inside and try to use a 12 volt light. Nothing. Battery is connected, but I notice also that the fridge is off, though it was on when I left home. Thinking the battery must not have survived the winter, I disconnect it again, and pull it from the trailer. Plug in the trailer, and 12 volt works again, but with an issue: frequently when I flip on one or another light, all 12 volt goes out just for a second, then comes back on. Not every light, not always, just sometimes. Also, from time to time, one or another of the GFCI circuit breakers pops. Not when I am doing anything, and no necessarily when there is anything plugged in.
Took the battery and had it tested. They said it is in great shape, tests normal, no problem.
Any ideas? Should I just replace the converter? Lack of 12 volts when on just the battery is a big concern. Suggestions?
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
