full_mosey
Oct 21, 2018Explorer
BFL13 wrote:
I think you guys are causing extra trouble by talking about "telecom" batts and "server UPS batts" when I can't relate that to my AGM "use" choices of "standby" and "cycle".
I'll take a shot at explaining.
Standby = UPS, as you would expect at a cell tower with unscheduled and infrequent frantic discharge. E.g., there may only be enough battery to allow for 15min until auto generator start.
Cycle = Camping, where the batteries are never totally at rest at float.
Acid starved/surplus: deals with a ratio of S(acid) to Pb(lead); not to be conflated with SG, or the water:acid ratio.
Starved = there is enough lead to absorb all the acid from the water.
Surplus = there is NOT enough lead to absorb all the acid from the water.
HTH;
John
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 21, 2026
