Onesweetvan's avatar
Onesweetvan
The Eternabond Blues......
I've used Eternabond Tape while patching/ repairing my 20 year old rubber roof and have, initially, been quite impressed with the product. I mostly used it to cover the joint between the aluminum siding and roof membrane after lifting off the rubber to repair some roof sheathing rott. I used acetone to clean all surfaces prior to using the tape.
The last time I worked on the roof was last summer and in the fall, parked in my driveway with much rain, the repairs seemed to hold up well. However on a recent trip the leading edge in both front and rear joints lifted up near the center and caused leaks. No tape residue was left, it came off as though I had never applied it.
Has anyone else had this tape lift off like I describe? What is the cure to prevent this in the future?
Looks like I'll probably redo the whole roof this summer, but I had planned on using Eternabond on the front and rear seams, now I'm not do sure about that.
Any thoughts?
Moved to Tech Issues forum from DIY.
Having RV issues? Connect with others who have been in your shoes.24,379 PostsLatest Activity: Apr 13, 2026
