pianotuna
Jan 14, 2015Nomad III
Hi,
I was speaking in terms of agm only using 50% and LI allowing 80% depth of discharge. The other factor is lack of voltage drop on the LI.
smkettner wrote:pianotuna wrote:Because of the strict voltage limits at both top and bottom I keep thinking lithium may need to be same size or larger to avoid a blackout in the wrong conditions.
Definitely exciting times! Given current lower pricing it is just as cheap to do 400 amp-hours of LI as 800 of AGM. So, if you demand nearly maintenance free batteries, LI is affordable now.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
