time2roll
Jan 14, 2015Nomad
NinerBikes wrote:
Heady times, and a whole new bunch of cutting edge industries and products will need to come down the line to meet our new needs.
You thoughts on generators and charge controllers and charging speed/run times for the new breed of batteries?
Progressive dynamics already has a converter for lithium batteries.
You are only going to get about 80 amps DC out of a Honda 2000 but 80 amps right to 95%+ charge would be sweet.
http://www.bestconverter.com/Inteli-Power-Lithium-Battery-Chargers_c_221.html
Actually the description says it goes 14.6 volts and is adjustable...
Anyone think this would be interesting on a wet cell?
I assume it kicks immediately down to float as it hits the target voltage similar to the PowerMax.
Actually does that make the PowerMax a good lithium charger?
http://www.progressivedyn.com/pdfs/lithium_battey_chargers_lit.pdf
PD links to Stark Power batteries for drop in replacement of lead-acid. BMS is built in.
http://www.starkpower.com/spnews/energystoragebatt/#!prettyPhoto
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
