groundhogy's avatar
groundhogy
The kid meets the furnace thermostat...
Hi,
So she’s been back there before...
Likes to pull the cover off the thermostat.
This time, she pulled the thermal expansion spring out.
(She did this just as i was finishing fixing the last thing she messed up. Lol)
Anyway, my questions..
Current thermostat is a mechanical Suburban. Has on/off switch and temperature setting. I haven’t yet pulled it off, so I don’t know how many wires are serving the thermostat. All i know is that there are two that go short/open for heat or no heat.
What are my replacement options?
Do i have to stick with the RV mechanical units or do i have the option of going to a digital unit?
Thanks in advance of your help.
groundhogy
  • SoundGuy wrote:
    dougrainer wrote:
    I Know about battery powered. But, not really needed for a basic mechanical wall furnace tstat. As another posted, what happens when the battery goes dead? Doug
    Seriously? Install a fresh set of AA batteries in the thermo at the beginning of each season - problem solved. :B
    Yep, changing the AAA batteries in our two Honeywell programmable thermostats is on our New Years Day "ToDo" list. Haven't had one fail us yet...
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    2oldman wrote:
    You don't have air?
    I was wondering the same thing. Is the 2-wire setup just for rigs with a furnace only and no air conditioner?
    What about a 2-speed fan? Doesn't that require an extra wire?
  • Ron3rd wrote:
    2oldman wrote:
    You don't have air?
    He may have a ceiling unit with an integrated thermostat. They're fairly common in smaller Class C's and TT's.
  • The two wire thermostat is for furnace only. When the thermostat calls for heat it just connects the two wires together. When the temperature is reached the thermostat breaks the connection between the two wires.
    The AC is on the ceiling and controlled by turning the knobs on the unit itself to both turn it on as well as adjusting the temperature.
    There is no additional wiring needed to replace a 2 wire mechanical thermostat with a battery powered digital thermostat.
    There is only one fan speed for the furnace. The high/low fan speed is for air conditioners not furnaces.
    1. Pull the cover off the mechanical unit
    2. Remove the two screws holding the unit to the wall
    3. Disconnect the two wires off the back of the old mechanical unit
    4. Carefully drill new mounting holes for the new thermostat.Connect wires according to instructions, 1 wire to the positive terminal and the second wire to the heat terminal
    5. Install batteries and test
    6. If no operation swap the wires
    7. Mount thermostat on the wall.
    This swap is relatively easy and should take about ten minutes.
  • Hi im back, the OP.
    I am waivering on digital vs mechanical.
    A couple mechanical thermostat questions..
    -I have discovered the heat anticipator. Referenced in a 2 wire system. I read that one common type is like a nicrome wire resistor that heats the thermostat. How is this possible in a 2 wire no electricity system?
    -Snap action thermostat? LuxPro has one (with anticipator) Are these good?
    -the old bi metal spring. If i remember correctly, my thermostat might have a very week magnet in there somewhere. Is that an anticipator?
  • The heat anticipator controls the length of time the furnace operates per cycle. It should be adjusted to the furnace control (milli)ampere setting listed on the furnace or measured thru the stat wires.
    I am confused by the phrase "2 wire no electricity system". What is the purpose of the wires, if not to conduct electricity?
    Snap action and bi-metal depend on flexing of metal due to temp changes, to open and close the stat contacts.
    The magnet inhibits contact chatter.
    The advantages of many digital stats are not insignificant.
    Easy to read lighted digital display
    Adjustable cycle rate
    Adjustable min/max temp settings
    Low stat battery freeze protection
    These features may be not available on all digital stats.
  • I thought in the 2 wire system, the wires get shorted or opened to turn furnace on and off.
    I was thinking there is no power in the wires.
    Thats why i was confused about a heating resistor living in the themostat asking for power.
    So there is power in the two wires?
    afaik there is voltage in one wire but nothing flowing. When the thermostat connects the wires it sends the voltage signal to the furnace to get started.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
