landyacht318
Oct 20, 2015Explorer
This 70mm x 10mm fan moves 28.93 cfm:
http://www.frozencpu.com/products/19957/fan-1255/Evercool_70mm_x_10mm_High_Speed_Fan_EC7010HH12CA.html?tl=g36c15s674
Here is a link to Delta's 70x15mm fan. Don;t know if it will fit, but it appears to be the strongest possible dual ball bearing fan which 'might' fit with a bigger hole cut out for it.
This is likely the most palatable price on a high speed dual ball bearing fan which Might fit.
http://www.amazon.com/DELTA-BRUSHLESS-AFB0712HHB-3-WIRE-70x15mm/dp/B0045JPH2I
I think my Google Fu has reached its limits.
Hope this helps and that a 70x15MM fan can be made to work inside the megawatt.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
