mperkins52's avatar
mperkins52
Norcold 1200 Muffin Fans
I had the recall for the heat sensor done in 2011 to my Norcold 1200LRIM . Since then I have had cooling issues in hot climates as many have. Not at the time being that familiar with my fridge, I did not know I could hear the fans run from inside the coach. I have read posts here and on other blogs that people have had their fans wired backwards when they received their coach. I was since I cannot see the wires coming from the fans, I looked at the wiring diagrams to see if I could figure it our. Are the fans wired along with the flapper heater wires into the board. The flapper heater works fine. I am trying to decide whether to install additional fans up at the condenser but wanted to see if I can figure out if the muffin fans will work before I do this. Can anyone tell me whether these 2 are wired together and if they are what color wire should be the ground? I am not going to just swap the flapper heater wires to see if that will make the fans run.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
