MEXICOWANDERER
Oct 21, 2015Explorer
You know those stiff plastic mesh (very dark gray) rectangular scrub pads? That's the plan. Sprayed with silicone lube on one side and slapped to the vertical fans intakes. Thanks Big Katuna.
It's real easy to think this is ridiculous level overkill. Until you come down here and find out when something fails you're screwed. Zero workarounds. Do you like paying two hundred thirteen dollars for a ten amp manual Schauer battery charger? Yes? Come on down! GC220 batteries? A year on the shelf? Si? Fork over a hundred ninety four dollars each.
That charger is going to be fast-filling a Lifeline that won't burp while swallowing a hundred amp charge rate. When the power comes back on for 55 minutes and the BiPAP battery is low, sonny, if you can't charge it, you screwed. CFE has a habit of fixing a line problem for several hours, reconnecting for a temporary zap then disconnecting for another several hours.
Who ya gonna complain to? Ya gotta be smarter than the problem.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
