dave17352
Nov 04, 2013Explorer II
bob_b wrote:MNtundraRet wrote:
With only 2 batteries you are going to be in for disappointment for any camping without shore-power. Especially with a 10 c.f. unit.
You are probably very right, but I have found another poster here that has had success using two batteries.
Here is why I think that it might work (check my math):
According to the yellow sticker, this Fridge uses 312kw/yr.
That is 312,000 watts per year.
That is 854.7 watts per day.
or 35.6 watts per hour
or .29 amps per hour (remember this thing isn't running all the time)
or 2.9 amp per hour at 12 volts.
One of those 12V overhead lights will suck down that much juice.
Running it for 10 hours over night should use 30 amp hours. My pair of batteries are rated at 245 amp hours or 123 usable amp hours. I think that I could make it work.
I'll find out soon enough, I'm sure:B
I think your fridge easily run overnight on your two batteries. Mine runs fine for 24 hours on my two interstate 75 amp hour marine rv batteries. I will go bigger for sure when time to replace though.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
