DryCamper11
Nov 05, 2013Explorer
pigman1 wrote:
we run a Tripp Lite PV 1250 FC modified sine wave inverter.... This inverter has run my Kitchen Aid, a 16 cu ft chest freezer, and a 3 1/2 cu ft basement freezer, all at the same time and full of fish on the way down from Alaska this summer. When I made a mistake and caused all three units to start at the same time, we only saw a 90% load indicating on our monitor panel.
I have the same inverter. It's great even when overloaded (but I do have trouble running the microwave on it). I want to make sure I understand what you've posted. If I understand you, you are running residential type freezer coolers on it that have motor driven compressors? Or are they heater element type (typical RV refrigerator that will optionally run on 120VAC) or thermoelectric type refrigerators (both types do not use a motor to drive a compressor).
Thanks for confirming this. I haven't run into anyone else using the Tripp Lite PV 1250 FC MSW inverter. It's a heavy beast, but unbelievably rugged.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
