Five_Nine
May 26, 2011Explorer
Thank you professor. Your response to this issue sure helps to confirm a lot of things to me. I bought a 3 stage intellegent converter to charge my batteries faster than the stock WFCO converter. I installed the converter 4' away from the batteries and installed 4 gauge wire attemping to do all the right things right to maximize voltage to my batteries. My IOTA DLS55 sure works great when plugged in to shore power. I only wish I would have plugged it into a kill-a-watt to understand what was really happening. Or better yet, thought about it before purchasing the converter and Champion 2000i to use as a combination. I was fooled by reading specifications that I didn't understand. My converter specs states 750 watt power output. I did know that the continous power rating of the genny was 1600 w but assumed I had plenty of spare capacity. Well...the education starts today.
From what I have experienced, my 55 amp converter is right on the edge of what the 2000i can handle, I will probably spend $150 on a smaller converter. I know that there are some converters with PF correction built in. Maybe I'll check into that too.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
