MrRchitty
Jun 14, 2011Explorer
professor95 wrote:MrRchitty wrote:
Like I said, "the lay-person" when it comes to Medicine. ;)
So, how is the "Lay Person" (meaning the person laying around right now :Z) doing with the injuries?
Oh my goodness, soooo much better. I am still out of work, though. However, I am walking around with a slight limp and am able to do some calf raises. Not sure on a return date yet. Still doing rehab 3 times a week. Thank you for asking.
And to maintain topic:
I am in receipt of my parallel cable from Costco. It was drop shipped from CPE to my house. Had Matt Cole's name on it. I hooked everything up and ran it last night. I powered the water heater for a bit and then turned it off. The rpm's are less obviously because the load is shared.
I tried to start the AC unit on eco mode. Gennie number 2 (the second one I bought) stalled. Gennie number 1 remained running, however, the AC unit did not start. Funny thing, though... While Gennie 2 was off, Gennie 1 was running and the power light was lit steady. (If you turn 1 Gennie off while paralleled, the overload light illuminates.)
I unplugged the camper and restarted Gennie 2. Turned eco off and started the AC unit without a hitch. I turned eco on and the Gennies lowered the rpm's which in turned reduced the noise. I did not meter it as the Gennies sit at the edge of the inside of the garage and camper is backed against the garage. So, I am sure there is an echo factor.
However, I am pleased. The noise level IMHO appears to be more tolerable this way than an open synch gennie running solo.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
