Angus_NB
Aug 03, 2011Explorer
After reading 40+ pages of the 171 in this thread I was nearly convinced that a trip to Costco was in my future.
The following has me concerned though;
I have a WFCO WF-8955PEC in my trailer. My main purpose for getting a generator is to recharge the two Group 24 batteries.
Is there something I can do to verify that the CPE 2000i is going to work for me?
I don't mind buying one and trying it out but I don't want to find out it can't charge my batteries when I am 100s of miles from home.
Searching_Ut wrote:
Biggest issue I have is that the little champion just doesn't like my WFCO 55 amp converter in my TT. The power factor on the converter is .67, which is murder on the generator. If I let my two type 24 batteries drop down to about half charge, the converter draws right around 700 watts when I first plug the trailer in to the generator. With that much of a reactive load the overload trips right around 700 to 720 watts, so half the time when I first plug the trailer in, it kicks the overload. Trying other less reactive loads I can get up to 1600 watts, sometimes slightly higher. The other issue with the converter in the TT is that the generator tends hunt a fair bit throttle wise when trying to power the TT with nothing else on, which is something it doesn't do nearly so much with other loads. On an intersting side note, I borrowed a little 2 cycle 1000 watt generator which is only rated for 800 continuous and it works great with the power convertor in the TT.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
