Angus_NB
Aug 10, 2011Explorer
Hybridhunter wrote:PrivatePilot wrote:
You need to use common sense. If you're going to demand a huge percentage of an inverter generators wattage suddenly, it's NOT realistic to expect it to be able to handle this situation 100% of the time from a low (or zero) load idle scenario..... .
Yeah, just because the other brands can do it, don't expect the same.
Seriously. :R
But the cheerleaders are filling in the blanks on this one
That gentleman stated he returned the one that had voltage sag for another one, and that the voltage sag is not the issue.
I'm not for or against the Champion. Can you tell me the make and model of a 1600 watt inverter generator that can handle the situation described above?
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
