pianotuna
Jan 19, 2018Nomad III
For your never off the grid an LI battery would be wonderful, if you have deep pockets.
Assuming lead acid:
What is the longest time the RV will not have shore power? Double that time, and measure the consumption. Use a Kill-a-watt meter. From that data it would be possible to calculate the number of amp-hours needed for the bank.
Assuming lead acid:
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
