12th_Man_Fan
Jun 13, 2017Explorer
byronlj wrote:
12th man,
If you read your level up manual it specifically says not to use the system to lift the vehicle off the ground for servicing. Liability issue I am sure. It also says you should have jack stands under the axles. I learned a long time ago when flipping my friends axles not to let them hang. I had the same problem you did.
Dave
Yes I read the manual but if you think I am going to use jacks or other devices when I have a 3 or four thousand dollar lift system you are mistaken. I only had the tires off the ground about an inch and I had blocks under the hydraulic cylinders where they were only extended about four inches and I only had one tire at a time off the vehicle.
Also I think you are mistaken about jack stands under the axles. Dexter does not want any support or lifting done with the axles. The frame maybe but not the axles.
Although most people including myself does not follow this advise either.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
