joshuajim
Nov 18, 2015Explorer II
Thermistor adjustor range
I have the dial type of thermistor on my Dometic 2652 RBX refer for about a year now. It doesn't seem to have any effect on the refer temp anymore. It measures 0 ohms on the warmest setting and 700 ohms on the coldest setting. This does not seem like enough as the thermistor test range is from 7000 to 10000 when in ice water.
It would seem that only adding 700 ohms to my thermistor which measures in the 8400 ohm range would be enough to vary the temp.
Any thoughts.
Any thoughts.
