MEXICOWANDERER
Mar 20, 2017Explorer
Well, it's like this...
I want that 11 position, snap break-before-make switch with resistor array
Configured for AGM and flooded battery voltage span.
The Megawatt voltage divider uses a convenient 10 ohms per tenth volt calibration factor.
An ON/ON 5 ohm primary bias switch can halve the resolution doubling the count to 22 positions.
While an ON/ON/ON switch can select thermistor, 11 switch or all-out 16.13 0 ohms charge rate (for equalizing).
Yeah - yeah I can use a low resistance Bourne pot to bias thereby configure the Thermistor circuit.
**** I can only wish this stuff was around 30 years ago.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
