Chris_Bryant
Oct 24, 2013Explorer II
Bad thermostat- if you turn the thermostat up, the pressure on the contacts is pretty high, but at a low temperature there just isn't enough pressure on the contacts to overcome any corrosion.
A quick free fix would be stick a business card between the contacts, push them together and move the card to burnish- also make sure the anticipator is set down to near off.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
