dougrainer
Jan 23, 2020Nomad
D.E.Bishop wrote:
I'm sorry Doug but I'm not aware what you mean by the Coleman HP blower motor.
This is your Main Basement AC. HP stands For Heat Pump. The basement AC has 2 motors. One motor is the outside Condensor fan motor. The other is the INSIDE whole house blower motor and this motor is the 2 speed motor. The wall tstat should have HI and LO fan speeds plus an AUTO setting. The Tstat has a HI and LO individual wires that goes to the Basement AC control board and is connected to the HI and LO inputs on the control board. When that HI or LO wire is energized, the control board then sends the signal to the HI or LO 120 wire on the Fan motor. Doug
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 19, 2026
