BFL13
Apr 08, 2018Explorer II
I had to replace the original mechanical thermostat in this 1991 rig that has an 8500 furnace. Honeywell tech support said this was their only suitable model (but you can get a digital one to work with some wiring creativity)
https://www.honeywellstore.com/store/products/honeywell-standard-millivolt-heat-manual-thermostat.htm
I got a digital one anyway, and got it to work with some help with the wiring.
http://www.canadiantire.ca/en/pdp/honey-non-programmable-thermostat-0529214p.html#srp
Posted: 11/29/17 11:45am by BFL13
I got that RTH111 thermostat and the wiring instructions made no sense so I called Honeywell and was told this thermostat will not work with my 12v system etc etc. (EDIT--that might have to do with the digital ones having their own batteries, which makes them possible to use anyway)
So I told him other guys use it and they say it works, so where do I attach my two 12v wires--pos and neg? (EDIT they are NOT pos and neg, just one wire that is connected and disconnected with the thermostat as its switch)
He said you can try using just W and R and makes no difference which for pos and neg. He says if it does not work,( EDIT-it did work) it will not fry the thermostat, it just won't work. ( He said the CT53K is the model I should have for this job.)
He said never mind the jumper between R and Rc, just leave it there)
