Chris_Bryant
May 04, 2016Explorer II
Your RM2410 does not use a thermister, it uses a dual mode thermostat, single thermostat for both LP and electric. It is one the rear of the refrigerator, with a shaft running from the knob back to the thermostat. It has a small capillary tube which runs in to the cabinet and is attached to the fins under a metal plate.
This part on the back of the refrigerator is under a white plastic cover- the silver block in the center is the thermostat itself.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
