Hemling's avatar
Hemling
Thermostat woes
We have the Coleman 'Airxcel' thermostat in our Keystone Sprinter. It is the basic unit, one long rectangular button on the bottom for mode, and then two triangular buttons to go up or down on temperature. Long story short, it is cutting out randomly on us, which is really frustrating. Sometimes it will blank out completely, in which case tapping on or messing with the unit will usually get it to 'power' back on, and sometimes it just kicks off before reaching the set temperature, but the display still functions so you can just restart it. When we are all in the camper for a while it will sometimes run flawlessly all day, other times it will glitch out 2-3 times within a half hour. If we are gone all day, we always come back to a 100+ degree camper. I have very little confidence in the cheapness of this unit, so I would much rather replace it with a wired, programmable one. What options are there that will still utilize the stock wiring? It's got red blue green white and yellow wires going into it.
  • wnjj's avatar
    wnjj
    Explorer II
    Pretty much any 12V thermostat will work. The wire colors usually follow a standard:
    Red = +12v
    Blue = gnd
    Green = high fan
    Yellow = cool (compressor)
    White = heat
    If you have any doubt you can find the wires on the AC unit to confirm.
  • Sorry - correction - there are actually six wires going into the back of the unit. Also, there is a brown wire that comes out of the wire packet from the wall, but has been snipped off and does not go into the thermostat at all. The diagram on the back of the unit seems to indicate that there is a blank spot corresponding to this wire's location. Maybe an unused wire for other models? I am sitting in the camper right now and it kicked off a few minutes ago, so I took it off the wall, manhandled it a bit, and it's back to working now, but the digital display is off. Jumped 5 degrees when I took it off the wall. Any help in getting a programmable unit installed is appreciated. I'm fine with electrical work and wiring, just don't want to go on a hunting expedition through harnesses. If I can get something that will work with the wires I have great, if not, I guess I'll wire in a toggle switch or something to bypass the thermostat.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
