cpd520's avatar
cpd520
Thetford flush issue
We have a Thetford Aqua-Magic STYLE PLUS Toilet. Sometime when we flush it works properly, partial pedal depress will run water into bowl and full depress dumps bowl content. Other times, any pedal depression will start to open ball valve, making it impossible to put water in the bowl.
The strange thing is, it's an intermittent problem.
I can't find any info on this particular problem online. I'm hoping someone here has run into this problem and has found a solution.
Any help out there?
  • Thanks guys, I found an old post with good info. So far seems to be a fix.
    HERE is the link to the post, in case someone else stumbles onto this thread looking for a solution.
  • WyoTraveler wrote:
    I never had any cables in my Thetford. The underside of flush handle is hollow with little boxes. Two protusions sticking out and into a box area control flush valve and water. Thetford suggested a new flush handle when I described problems with them. I pulled off the handle. Thetford describes how on their site. After looking at the handle design I decided to replace it with a Dometic toilet. Easy replacement and no trouble since.
    his is a plus cable actuated
  • I never had any cables in my Thetford. The underside of flush handle is hollow with little boxes. Two protusions sticking out and into a box area control flush valve and water. Thetford suggested a new flush handle when I described problems with them. I pulled off the handle. Thetford describes how on their site. After looking at the handle design I decided to replace it with a Dometic toilet. Easy replacement and no trouble since.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Some years ago I had the weather hit 11 dergrees.. Froze the cold water line crossing over from the Curb (Where the pump is) to the Driver's side (Half bath) which is that same type (though a different make) toilet.
    Oh, no damage, it froze in the middle of the run and Pex does not mind a bit of freezing and thawing. Now the connections on each END of that line.... Well they were heated so they did not freeze.
    So what did I do?
    I grabed my 4 cup measuring cup and put it in the sink.. Filled it with HOT water from the sink and used it to "Flush" the toilet.> Worked great
    Though I do admit it was just for that one night.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
