wrgrs50s
Jan 04, 2017Explorer
Sorry about that. I see now that info on changing the thetford valves is hard to find. The only info I found was on replacing the valves on an airstream trailer and it shows that they all have 4 screws that attach them directly to a flange on the tank. If I'm understanding correctly, the valve that has a collar on both sides, one side is glued to the down pipe as you suspect, and the other side is a slip joint with a rubber seal that is pulled together at the bottom of the tank by the 4 screws into the flange on the tank. The 4 screws may be difficult to see or to get to.
If this is the case, to replace it would require you to cut the down pipe and use a rubber clamp joint to reassemble with a new valve.
Not sure if any of this info fits your application without having my eyes on it, but if anything else, just food for thought.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
